TwinTurbo.NET: Nissan 300ZX forum - Yep, Dryer Switch if its a 134a Replacement
Cjw3
on July 18, 2024 at 8:26 PM
I added about 6oz of Pag 100.
posted by Stokens (AR)
on July 18, 2024 at 08:07 PM
Or you can use a Murray Switch 25829 that is available by O'Reillys Auto for $34.. Low Pressure Cut out/In is 29/30 PSI and the High Cut Out is 391/304 PSI..
Re-using R12 Compressor
Stokens (AR)
12:38:45 07/18/24
follow up
Stokens (AR)
12:42:59 07/18/24
Flush the Compressor
Cjw3
19:31:29 07/18/24
Stokens (AR)
20:07:48 07/18/24
Yep, Dryer Switch if its a 134a Replacement -
Cjw3
20:26:09 07/18/24
35829?
Stokens (AR)
21:41:33 07/18/24
You need to switch from the LP only to the HP/LP Switch (n/m)
Cjw3
07:19:39 07/19/24
Gotcha - I ordered one
Stokens (AR)
09:53:46 07/19/24
Re: follow up
Kvert
23:58:22 07/18/24
Thanks!
Stokens (AR)
09:31:22 07/19/24
Re: Thanks!
Kvert
14:07:12 07/19/24
Four Seasons Issues
Denis
17:20:03 07/19/24
New compressors have been unavailable for years.
22:52:42 07/29/24
Still....
23:09:47 07/29/24
Here is the part number I ordered in 2021 and...
Denis
12:26:05 07/30/24
My point is that it has not been available for going on 5
17:22:10 07/30/24
understand, thanks for the follow-up. (n/m)
Denis
21:12:59 07/30/24
Z32 compressors are the same R12 vs R134a, just different
22:54:36 07/29/24
